COVID 19 Solution Challenge #IndiaFightsCorona
    Government of India is taking all necessary steps to ensure that we are prepared well to face the challenge and threat posed by the growing pandemic of COVID 19 – the Corona Virus. With the active support of the people of India, we have been able to contain the spread of the virus in our country.
    The most important factor in preventing the spread of the Virus locally is to empower the citizens with the right information and taking precautions as per the advisories being issued by the Ministry of Health & Family Welfare. Further, we are also getting inputs with regard to individuals and companies who have developed technologies and innovative solutions, Bioinformatics, datasets, Apps for diagnosis etc that can be leveraged for strengthening the fight against Corona.
    In order to involve the community in the fight against the Virus, we would want you to share your solutions to help fight #Coronavirus . Submitted solutions will be evaluated for adoption and those selected will be suitable rewarded.
    Be a part of the mission against Coronavirus!
    ELIGIBILITY CRITERIA -
    • Applicants who want to participate in COVID 19 Solution Challenge can be individuals or Startups that comply with the definition of a startup as notified by DPIIT vide order no G.S.R. 127(E) dated 19th February 2019.
    • For the product to be developed as part of COVID 19 Solution Challenge if any IPR/Patent is being used, contesting entity must possess the legitimate rights to use the IPR/Patents.
    MyGov will have the right to chose all submitted solutions and consider it for deployment by scaling it up if found feasible.
    Last Date of Participation - 31st March 2020
    Registration Link: https://innovate.mygov.in/covid19/
