CERN updates its Open Hardware Licence
  • Version 2.0 of the CERN Open Hardware Licence has been released, introducing three variants meant to cater to different collaborative models
    CERN Open Hardware Licence (OHL) is a legal framework to facilitate knowledge exchange on hardware design. Several years after its first publication in 2011, CERN released version 2.0 of the CERN Open Hardware Licence (CERN-OHL) in 2020, which governs the use, copying, modification and distribution of hardware design documentation, and the manufacture and distribution of any resulting products. The latest version uses simpler terminology, introduces three variants of the licence, and broadens its range to include designs that go from artistic to mechanical to electronic, as well as adapting the licence to cases such as application-specific integrated circuits (ASICs) and field-programmable gate arrays (FPGAs). It can even be used to license software.
    more details: https://kt.cern/ohlv2
