Murata Launches World's Smallest 100NF MLCC Ceramic Capacitor for 5G Smart Phones
    Adding an 8-bit camera sensor to the Portenta Carrier camera connector will help you implement any kind of computer vision application. And if the onboard computing power is not enough, you could enhance your board’s AI capabilities by adding state-of-the-art Machine Learning modules through the Carrier’s miniPCI connector (like Google’s Coral unit of computation).
  • 0
    @kowshik1729 thanks bro
