Help needed for drone simulator for Mac
  • Project help: Problem with connecting tx(avionic rcb6i) as a joystick to my Mac using aux cable! Does anyone know any suitable driver(to recieve and decode ppm signals from tx and encode and transmit ppm to tx)?
    Adding an 8-bit camera sensor to the Portenta Carrier camera connector will help you implement any kind of computer vision application. And if the onboard computing power is not enough, you could enhance your board’s AI capabilities by adding state-of-the-art Machine Learning modules through the Carrier’s miniPCI connector (like Google’s Coral unit of computation).
  • 0
    @kowshik1729 thanks bro
