HackAway 24 hour hackathon
  • HACK-AWAY
    ๐Ÿค”๐ŸŒ "What can I do for the world?" ๐ŸŒ๐Ÿค”
    A question that has been raised millions of times by students all over the world. A question often placed aside due to the notion that there are a billion others to do that work for you. ๐Ÿ˜”๐Ÿ˜”
    Not any more.โŒ Be the change you want to bring to this world with Rajagiri in ๐Ÿง Hack-Away๐Ÿง , a theme based hardware hackathon with a vision to save the earth. ๐Ÿ’ช๐Ÿ’ช
    Grind your gearsโš™ this season to find the ultimate solution, mixed with awesome activities and a night full of *brainstorming fun!*๐ŸŒƒ๐ŸŽ‰๐Ÿฅณ๐Ÿฅณ
    Time: 15th November 5:00 pm to 16th November 5:00 pm
    Theme: Save the earth ๐ŸŒŽ
    VENUE : RAJAGIRI COLLEGE OF ENGINEERING
    AND TECHNOLOGY
    ๐Ÿ’ฐPrizes Worth 10K๐Ÿ’ฐ
    Registration fees: Rs. 300 per head
    โš 2-4 Members per Teamโš
    Registrations is live!!
    Registration link:
    https://www.yepdesk.com/hackaway/
    Contact :
    Eldho 9745161124
    Aravind :8848128821
    Adding an 8-bit camera sensor to the Portenta Carrier camera connector will help you implement any kind of computer vision application. And if the onboard computing power is not enough, you could enhance your boardโ€™s AI capabilities by adding state-of-the-art Machine Learning modules through the Carrierโ€™s miniPCI connector (like Googleโ€™s Coral unit of computation).
  • 0
    @kowshik1729 thanks bro
