Water depth sensor
  • @Ggreeshma-stani Nailed the PCB in terms of the schematic. But you got it a little bad on the layout side. There are some thumb rules while designing a layout of PCB.
    Always place the oscillator and it's capacitors(C1, C2) near to the IC. If you have a doubt on this try checking the Arduino boards or any other boards. you will find an SMD chip crystal alongside of the Arduino XTAL pins. If you ask the reason for this that's simple, to avoid noise creeping in. Crystals provide the clock to the entire digital logic inside the IC. So, there should not be any noise in it. If noise is there, obviously you'll have timing issues.
    The bypass caps on the voltage regulator must be placed close to the regulator's input and output pins. The reason for this is also pretty simple, bypass caps will filter out noise coming from the power supply and few other reasons too. So, try placing these bypass caps as close as possible to IC.
    Apart from these points, the PCB looked good. Great work. Remember that this message is not to discourage you but just to give a suggestion so that you'll improve it in the next design.
  • Calling All Innovators - IgniteX Accelerator
    Do you have a solution that can reduce the severity of the coronavirus outbreak, but need help commercializing and rapidly deploying? The Black & Veatch COVID-19 Response Accelerator is designed for growing companies looking to scale emerging solutions to save lives, help communities cope, and protect the economy.
    Apply here https://www.bvignite.com/
    @salmanfaris the pressure range that we have to measure is between 5-10 cmH20 (ie almost 0.07 - 0.0.14 psi)
    final redone project eagle.png final project redone.png final project redone back view.png final project eagle.png
  • Startup India - Challange
    startup-india
    The Challenge is open to all the Startups, Companies, Innovators etc. whose innovation can plug the gap between the demand and supply of essential medical items to fight the Covid-19 outbreak as well as an innovative tech for applications such as motion tracking, geofencing, fake news detection, etc.
    Powered by Startup India
    Apply before Wednesday, 15th April
    Submit Solutions to combat Covid19 here -https://www.startupindia.gov.in/content/sih/en/ams-application/challenge.html?applicationId=5e79126ee4b055bfaea9ef66
