Openhack19
  • Hey folks,
    Want to write code that will touch the lives of hundreds of thousands of people? Are you waiting for that opportunity to give back to the society? Look no further! OpenHack- A 2 day immersive Hackathon organized by KeralaRescue team on 26th and 27th of October to unite people to work upon a single project , building a disaster management, awareness and alertness platform that can be used by the government and communities anywhere for spreading awareness,and for efficient coordination of relief and related activities .
    🗺 : Integrated Start Up Complex, Kalamassery
    🗓 : 26 and 27 October, 2019
    Registration is open at https://openhack.tech
