Getting Started with Azure Sphere MT620
  • Here is the Getting Started with Azure Sphere MT620, please share your suggestion and opinions 😀
    This blog post will explain how to set up and run a Hello-World program in Microsoft Azure Sphere MT620 for the first time. If you already did the setup then skip the whole post.
    Prerequisites:
    • An Azure Sphere Development Kit
    • A PC running Windows 10 Anniversary Update or later
    • Visual Studio 2019 Enterprise, Professional, or Community version 16.04 or later; or Visual Studio 2017 version 15.9 or later.
    https://blog.makergram.com/setup-microsoft-azure-sphere-mt620/
