Fablab Open House 26/06/2019
  • Visit fablab Kochi or Trivandrum on Saturday at 11.00 AM to know more about the training programs and facilities available at FabLab. Take a free guided tour and see machines in action!
    Entry is free and open to all.
    Register here: http://bit.do/faboh
