Help need in Arduino coding : Arduino with HC05
  • Plese help me to make a Arduino program to make the led blink continuously, when the hc-05 bluetooth module get disconnected from mobile.
  • Hi @Geethesh , Since HC05 is Interfaced with Serial (UART), you can check whether it connected or not in the Serial.available() function call.
    if (Serial.available() > 0) { // Checks whether data is comming from the serial port
      data = Serial.read(); // Reads the data from the serial port
    else {
      // Write what you need if serial is not connected
    full Implementation .
    #define led 13
    void setup()
      pinMode(led, OUTPUT);
    void loop()
      else {
        ledBlink();
    void ledBlink()
      digitalWrite(led, HIGH);
      delay(100);
      digitalWrite(led, LOW);
      delay(100);
    All the best .
