Kuttycoders chapter 2
  • Kuttycoders is a 3 day bootcamp that aims to build a coding literacy among the students in the age group 10 to 17. Through this program get ready to dive into the interesting world of technology and learn from experts.
    So this Onam get ready to surprise Maveli with your coding skills.
    This Onam get ready to be a tech expert as Kuttycoders is back with season 2. With a successful season 1, the team is proud to announce the season 2 of this amazing program aimed at students in the age group 10 to 17.
    📆 Date - September 7,8,9
    📍 Venue - Cittic, Cusat, Kalamassery
    Registration link in the website kuttycoders.in
    Registration fee of Rs.600/-
  • Thanks for sharing 😊 .
