Kerala Startup Mission Fellowship - 2019
  • Government of Kerala is offering a one-year fellowship to experienced professionals and motivated youngsters interested in contributing to the Government’s mission of making Kerala a vibrant hub of tech startups and talent pool skilled in emerging technologies. Selected fellows will work with Kerala Startup Mission, other Government bodies, industry leaders and associations, startups and other stakeholders to achieve the goals of the fellowship. Each fellow will be assigned a mentor and/or a host institute who will be able to provide guidance and necessary connections.
    • Senior Fellow - Product Marketing
      Minimum 5 years of total experience. The candidate should have startup exposure and proven experience of product marketing or should have been a part of the team which has successfully rolled out tech products into the market.
      Fellowship amount: Rs. 60k - 80k per month
      No of Vacancy: 1
    • Research Fellowships: Future Technologies
      Eligibility: B.Tech/BE with 1-year experience or
      Relevant Industry certification on one of the future technologies + 2 years experience
      Stipend: 20-25k
      No. of vacancy: 2
    • Fellowship: IEDC
      Work closely with KSUM, ICTAcademy of Kerala, the network of IEDC’s in the State and other organisations working towards promoting talent, innovation and entrepreneurship in colleges. Fellows are expected to
      Visit various IEDC’s in the State, and spread awareness about various opportunities available for students.
      Build communities inside colleges, identify potential leaders in these communities and help them create a positive change.
      specific projects as required, which may include outreach, special events and other daily work that aligns with fellows’ abilities and goals.
      Fellowship amount: Upto Rs. 15k - 20k per month for full-time fellowship;
      Rs. 5k - 10k per month for part time fellowship
      No. of vacancy: 4
    • Senior Fellow: Startup Investments
      The candidate should have good exposure to the startup ecosystem and investor networks. It is ideal to have experience handling startup investments.
      Experience: Minimum 5 years experience
      No of Vacancy: 1
    • Senior Fellow: Women empowerment
      Masters degree with minimum 3 years of work experience
      Experience: Minimum 3 years experience
      No of Vacancy: 1
    • Incubation Fellowship
      Founder of a startup which has raised at least 50k USD or has been acquired.
      Experience: Minimum of 3 years experience
      Fellowship amount: Rs. 30-60k per month
      No of Vacancy: 2
    More Details : https://startupmission.kerala.gov.in/tifp/
