CODE-VID 19 -Kerala Police Cyberdome Online Hackathon
  • Kerala Police Cyberdome is conducting Online Hackathon “CODE-VID-19” to find IT based innovative solutions that can help Police in the fight against COVID-19. Inviting tech-community across India to come forward and contribute to this mission. Showcase your Technical skills to Stop-Prevent-Contain the Pandemic. CODE-VID 19 envisages to find technology based innovative solutions for the Police to effectively contain corona virus for the benefit of society. The last date of submission of your idea and technical solutions is 29-03-2020. The best idea will be suitably rewarded.
    Registration Link: https://forms.gle/PiJho8MsGkibVUgTA
