Support needed for NXP KL25Z Freedom board
  • Hello,
    I've been practicing ARM programming over NXP's Kinetis series KL25Z board. Unlike the kinetis HAL approach, I am practicing entirely using baremetal coding with Keil U vision. I am facing problems in coding the UART programme of this board. If anyone has any prior experience over this board please do help me out guys. I have attached the link for the datasheet of this board FRDM KL25Z Datasheet Link
    Thanks in advance
  • Hi @kowshik1729 ,
    Could you please specify what problem you are facing while using UART in KL25Z? it will be more helpful to understand your situation. also, try to attach some useful error log.
    thank youu
  • @Richu-Bini thanks for posting the question . just for a brief about pwm, pulse width modulation technique is a method to change the duty cycle of a wave. Which means you can determine how much time a signal must be on or off.
    So, coming to the question, software pwm and hardware pwm is just two different ways of producing same result. In software(referring Arduino here) you'll just write a value between 0 to 255 inorder to determine duty cycle percentage. For example 0 is 0% duty cycle which means the cycle is on for 0% of whole time, similarly 127 means 50% of time cycle will be on and 255 means signal will be on for ever. This is regarding software.
    Coming to hardware, you can generate a pwm signal using very simple passive component, called as potentiometer and 555 timer IC by using 555 timer as bistable multivibrator(The generated output will have two stable states 0 and Vmax, hence the name bistable) and changing the resistance using a potentiometer generates different duty cycles. This is the difference between hardware and software pwm. Please let me know if I haven't explained what you have expected.
    This month we are discussing Psychology and Perils of Polyglot/Mixed Language Programming
    by Praseed Pai
    Author of .Net Design Patterns and
    C++ Reactive Programming,
    Father of SLANG Compiler.
    Nowadays, every developer in the world ought to be a Polyglot (Programmer) to do something worthwhile in the industry. But, most are not prepared to get into that groove. The Session will give necessary conceptual, ontological, linguistic and formal background to navigate between programming languages with ease. The Session has got examples in C++, C#, Java, Scala, Python, JS, Python/C interface, Java Native Interface, P/Invoke, COM interop, RxJava/RxJS./Rxcpp/Rx.net etc. All code snippets are taken from real-life projects which the presenter has been part of, in the past two decades. The session also covers some pitfalls which an aspiring Polyglot Programmer should be watchful, as well.
    Don't miss it, book your seats today. It's a golden opportunity for all Enthusiasts to listen from the true industry experts!
    Come and join​ us! Have a Java Coffee 🙂
    Date & Time : 29th February 2020 02:30 PM to 05:30 PM
    Location       : KeyValue Software Systems Pvt Ltd, SmartCity Kakkanad
    Map : https://goo.gl/maps/7VruKuDzbHkNwcc87
    Grab your ticket at: http://bit.do/KJUG012
    What is the difference between hardware pwm and software pwm
  • Flat/ball end
    flat end leaves flat surface profile on the stock and are good for removing large volume of material, but steps are formed when used for making curved surfaces. Ball end leaves curved surfaces and forms smooth curved finish while cutting cavities. They are used for finishing cuts.
