Fighting Covid-19 using open-source electronics and digital fabrication.
  • Hi Makers,
    Community around the world is working on prototypes and projects aimed at fighting Covid-19 using open-source electronics and digital fabrication, this Thread is created to centralize all the hacks to share with other people.
    Contribute some useful hacks be part of the Covid-19 Fight
